honda vision de-restrict?
Discussion in 'Scooter Tuning' started by jade perfect, May 4, 2013.
  1. jade perfect
    jade perfect New Member
    honda vision 1988
    does anyone know if its possible to de-restrict a honda vision 1988? thanks guysssss
  2. scootzmadness
    none of mine were ever restricted but usually if theyre used its already been done but you cant really tell because visions are slow anyway ! if you want more speed out of a vision, mallossi sell a variator kit for them and get a Kevlar belt too ! :) the only restrictions on a vision ive heard of are in the exhaust pipe there will be a spacer just by the header and there will be a spacer in the variator. don't bother changing the cdi as some people will tell you as they are not restricted from factory and are actually better than the aftermarket cdi`s :) hope this helped a bit :)
  3. Mark Emerson Trentham
    Pretty sure malossi does a gear - up kit too!,
    There are alot of b/bore kits out there as well,
    would'nt touch them for personal reasons,but if
    you decided to go that route - just remember most
    of the parts in your motor would probaly be quite
    old,an unless there was a full comprehensive rebuild
    it could be a short! term thing. :) .
  4. scootzmadness
    mallossi have done a few parts for the vision but if you want to keep your vision reliable id say just get the variator kit + Kevlar belt, never had experience or know of people who have had experience with the gear up kit but I honestly don't see the point unless your going to do a full race set up (72cc Malossi MHR and Stuffer Crank OKO24, 28mm Simioni, ZX Trans, 7.58:1 gear up kit) and your never going to see more than 50-60 + tbh, with just a variator kit + Kevlar belt you can get 35mph, change the tyres to michelin S1 90/90 10`s and you MIGHT see another 5mph. theres quite a few tuned visions around my area but my sa50 was the only one that would start up first kick every single time weather it was sat for weeks or not it would start without fail. the tuned ones round here are ermmmmm whats that word again................... unreliable :) haha
  5. Mark Emerson Trentham
    Think i'd be quite happy in long-run if it topped out round 40mph,
    after all pretty much fastest road be taking her on,just don't like
    the idea of riding around on a bike (alongside all other 50's+),that should'nt have been restricted
    in the 1st place!.
  6. scootzmadness
    like I say best bet is variator + belt + tyres to keep it reliable, I did the variator and belt mod and was best £75 spent ever, did the tyre mod to my nb50 and it did improve handling etc worth £30 a tyre, there are other things you can do to get these beautiful little machines faster but if you just want 35-40mph then variator+belt+tyres :) hope I helped
  7. jade perfect
    honda vision 1988
    thanks every that was alll great advice!!!!
  8. MiNoR cOnFuSiOn
    last i checked you couldnt even get replacment cranks for these or melody's... so a bad idea tuning one
  9. Mark Emerson Trentham
    Ran an '86' ne for 10 months last year,found a replacement crank quite plentiful -running
    on average ©£70.ish.
  10. MiNoR cOnFuSiOn
    i remember a young lad in tag mag YEARS ago saying about a melody crank for his home brew supercharged engine being impossible to find... guess he diddnt look too far/there different.. been years since i was near a honda.. is that the pw style engine?
  11. Mark Emerson Trentham
    Don't know that term,
    only ran and serviced the bike during otr/before making sorn,
    for long-term original spec.but 'improved'rebuild.
    Learning much more now ,doing occasional research in between
    gathering parts.
  12. jamespee
    jamespee Member
    Change the wheels is a good idea
  13. scootzmadness
    no need to change the wheels on the little Hondas, the tyres yes, im running 90/90-10 front and rear now and getting 40mph (took it to family friends farm to test)
  14. Mark Emerson Trentham
    When I had my ne otr it'd do 35mph no problemo,
    always constantly felt there was plenty more in reserve!,
    having dismantled her or a longish+ rebuild/found out that
    the guy ?before me who owned it fitted a fully de-restricted
    motor but left the original pipe(very heavily restricted) + carb.,
    ,i used to scare the living daylights out of much/much bigger bikes
    in traffic as it used to go like a scalded cat!.,
    I would never change original wheels as for nipping round local london
    streets on good tyres you can't beat her! :D.mark.
    milo2025 likes this.
