how to destrict my aprilia rs50 2000
Discussion in 'General Tuning' started by scottdickinson, Feb 18, 2012.
  1. scottdickinson
    scottdickinson New Member
    iv just bought my aprilia rs50 a few weeks ago. its already has a sports exhaust on it cant fined the restricter in it so i think its been remove.
    it only gose 30 mph ;( sick of been taken over by my mates that can go way faster than 30
    please help me
  2. revolution
    revolution Member
    as far as i can see having read up on the subject it seems that the only restrictors on the 2000 model was the exhaust, and if that has been changed for a sports exhaust you should jet to around 84/86 for best results with the pipe, another suggestion was to change the 12mm flatside dellorto for a 21mm carb and jet that to suit, but the manifold and reedblock/reeds should be changed along with it, hope this helps
  3. scottdickinson
    thanx for replying am hopeing to change the carb and up jet it. as for the manifold am having trouble finding one
    as the factory manifold there are two pipes coming of it.one to the water pump and the other to the head of the piston but when i try and look for one i seem to fined ones without the connectors on it .
    iv also fined out that the sprocket could be restricted ?? dont know if this is true
    but anyways thanx for your help
  4. revolution
    revolution Member
    by saying that the sprockets could be restricted they would be talking about the gearing ratio- i.e the tooth size of the front and rear sprockets, these being changed can change the characteristics of the engine but i wouldnt know what to recommend unfortunately, maybe read up on the subject and see what others have tried and how it worked out for them?
  5. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    The restrictor is the inlet manifold and the carb, both are way too small. You need to find a derestricted manifold and a 21mm :)
    Or...... swap it for my aerox ;)
  6. scottdickinson
    iv read as much as i could fined i can change the sprocket.... well il have to change the whole set chain and front and back sprocket. its just a bit of a pain lol
    thanx anyways
  7. scottdickinson
    wot have you done to the aerox?
  8. FiddyRox
    Doppler Pipe with Gianelli carbon silencer, new cylinder with port work on the exhaust port, 17.5mm carb, Topracing Variator with Stage6 rollers and an adjustable pmtuning clutch.
    The speedo goes round to about 68-70mph so i guess thats a true 55-60. It gets there pretty quick too.
  9. scottdickinson
    when you said about the carb and mainfold becoz my carb is all standard i cant seem to fined out wot type is the main jet.. (m5 or m6).
    wish mine went 55 lol am lucky if i get 40 lol
  10. FiddyRox
    Im not sure tbh, youre gonna have to take yours off and see. I wouldve thought it would be an m6.
    Been wanting an rs50 for a while, if you ever want to swap or sell it let me know.
  11. scottdickinson
    ok cool have you got any pics of it
  12. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    ask an aprilia dealer what you need. Are you sure the pipe is a sports pipe or has it simply had an aftermarlet end can fitted? its the exhaust chamber thats restricting.
    the rs 50 will be pretty nippy when sorted so id keep at it if you like it
