Yamaha jog r derestricting.
Discussion in 'Scooter Tuning' started by -yamaha-rida-, Jan 31, 2009.
  1. -yamaha-rida-
    -yamaha-rida- New Member
    hello all im new to this forum, and im wondering how to fully derestrict my yamaha jog r (air cooled), i have derestricted the exhaust and now what do i need to do? also, i would like to get some different rollers for it. it has the standard exhaust by the way. any weights recomented? cheers :pimp:
  2. adz452
    adz452 Member
    Vespa T5
    take your side casing off and remove the nut on the left hand side at the front pully either with a variator locking tool which can be purchased from www.donotlink-pedstop.co.uk orrrr use a high impact gun on,
    after remove the front pulley and the belt remove the varaitor and you shall see a big fat washer get rid of that and reassemable vice versa..... ;)
    hope this helps
  3. INO
    INO Member
    Or you can remove the pully with a pair of molgrips and a ring spanner or any spanner and just give it a couple of hits should come undone
  4. adz452
    adz452 Member
    Vespa T5
    bodge ftw :punk: :D
  5. -yamaha-rida-
    cheers lads
  6. NRG_JON_92
    NRG_JON_92 New Member
    You will also require a torque wrench ;) for NRG's its 40-44 Nm
  7. adz452
    adz452 Member
    Vespa T5
    mmm between 40-45 should be fine
